Clears the counters associated with the ports.
| ports | Clears port-related statistics on specified ports or all ports in the system. |
| port_list | Port list for clear operation. |
| all | All ports in the system. |
All ports.
If you use the clear counters command with no keyword, the system clears the counters for all applications.The following example clears the counters on all ports:
clear counters ports all
This command was first available in ExtremeXOS 11.3.
This command was updated in ExtremeXOS 15.5 to include the port_list variable and the all keyword.
